Claude resuelve dos problemas pendientes en el ámbito de la física de los agujeros negros
    • 5268
    Claude ha resuelto dos problemas abiertos de la física teórica. En el primero, [...] Claude demostró que una transición repentina asociada a la formación de agujeros negros persiste incluso cuando el espaciotiempo ya no tiene una forma definida. En el segundo, Claude determinó el límite exacto de la versión más sencilla de una técnica utilizada para poner a prueba las teorías candidatas de la gravedad cuántica.
    En esta entrada se explican ambos hallazgos, primero en términos sencillos y después con más detalle técnico
    Claude Fable 5.2 has solved two open problems in theoretical physics. Both concern black holes and the search for a theory of quantum gravity.
    Los preprints
    The spinless modular bootstrap bounds the dimension $\Delta_1$ of the lightest primary other than the vacuum in a two-dimensional conformal field theory, using only modular $S$ invariance of the torus partition function at zero angular potential. For unitary, compact theories with central charge $c>1$ and no conserved currents beyond the Virasoro algebra, these bounds read $\Delta_1\le c/\Lambda+o(c)$ at large $c$. The best slope $\Lambda$ was known only to lie between $8.503$ and $12$, where the bound would reach the BTZ black hole threshold. We show that it is exactly $\Lambda_V=12\pi^2/(\pi^2+4\,\mathrm{arcsinh}^2 1)\approx9.1266$. No linear functional in a class that contains all finite combinations of derivatives improves on $c/\Lambda_V$ by more than $O(c^{1/3}\log^{2/3}c)$, and an explicit functional gives $\Delta_1
    In anti-de Sitter space a black hole forms through a first-order phase transition, discovered by Hawking and Page. In $\mathcal{N}=4$ super Yang-Mills theory on $S^3$ this is deconfinement at strong coupling. Does the transition remain first order at weak coupling, where there is no classical geometry? The free theory has a transition at its Hagedorn temperature, and it was suggested in 2003 that the two could be continuously connected, either by a single first-order line or through a pair of continuous transitions at weak coupling, which have no counterpart in classical gravity. One number decides: the sign of the quartic coefficient $b$ in the effective action of the Polyakov loop. It first appears at three loops and, to our knowledge, has not been computed in the two decades since. We find $b=-1.48\times10^{-3}\,\lambda^2$, where $\lambda$ is the 't Hooft coupling. The transition is first order. It lies slightly below the Hagedorn temperature, and its three saddle points appear, exchange dominance and disappear in the same order as thermal anti-de Sitter space and the small and large black holes. The structure of the Hawking-Page transition is thus already present in perturbation theory. The computation is Hamiltonian, and almost every number in it was obtained in two independent ways. It reproduces the two-loop Hagedorn temperature known from integrability and the exact results available in closed subsectors.
